ok im at my wits end and im hoping someone will know the answer to my problem.
i built a 360 for my bomber class circle track. it is a 1977 block. the pistons are stock size, i installed new rings.
i installed a remaned crack with matching bearings.. a high volume oil pump. my mechanic friend installed new cam bearings. i installed new cam ,and lifters.
we put the motor in the car started it up . it had 30 psi at idle. went to the race track made 5 laps-lost all oil pressure. shut it down. i pulled the sending unit and had pressure. just not enough to really effect the guage.
took the car home pulled the motor put it on a stand, pulled the pan looked at every bearing-rod and main. looked awsome. replaced the pump. put the pan back on. filled with oil and spun the pump with my drill. it didnt bog the drill very much, but produced 30 psi at 750rpm(estimate). reinstalled motor. i spun the oil pump one last time before i dropped the distributor-30 psi same rpms.
i started the car up and had real low oil pressure. didnt shoot up with rpms. shut it down. reinstalled priming shaft got 30 psi at approx 750 rpm.
so i had my buddy run the drill. i made sure i had pressure, the at the same time he was spinning the drill i turned the motor over with the starter. oil pressure dropped to 0. i stopped turning the motor over and turned the pump with the drill-- nothing. cant even get the 30 psi i had before. ive tried turning the motor over by hand to see if there is a spot in the revolution that will get me oil pressure-cant. can someone pleased help????? oh ya btw the small freeze plug that goes in the oil galley is there and its solid.
any and all help is needed. thanks
