[SOLD] 11.75 Slider type front disk setup, just add knuckles
goldduster318
Overzealous Car Modifier
Lake Orion, MI
11.75 Disk Brake setup including calipers, pads, rotors, caliper brackets, wheel bearings, dust shields, hoses, and mounting bolts. Just removed from my 1970 Plymouth Duster in March 2017. Calipers are the 2.75" diameter for a 76 Duster with steel pistons and were fresh remans in 2014. Hoses were also new at the same time. This is set up to mount the calipers forward as in a 1973+ A-body. The Dust shields are original ones from a 1974 Duster. The caliper brackets are reproductions from Dr Diff and are from 2014. Very low miles on this and pads
If you do not have disk brakes, you will just need to add knuckles for a 73+ A/B/E/F/M/J body and upper control arms if you have the small bolt setup.
Rotors have long wheel studs for running modern aluminum wheels. I can include the stock length ones as well if you would like.
$175+ Shipping, shipping will be expensive due to size and weight. Or you can pick up in Lake Orion, MI 48362.
