doc540
thought this might help someone
For the '60-'61 Slant Six engines, these part numbers will work: (but they are not the ONLY mounts and part numbers)
Right side/passenger - 2203038
This mount to frame flange has both a lower bolt and an upper castle-style lock nut on the top.
Left side/driver: 2128821
(note: the lower bracket to frame bolt does not have a nut - it threads into the frame plate. You only have to remove it from the top. No wrench on the bottom is needed.
