1964 Dart Post Project
dart4forte
Mesa, AZ
Rating - 95%
19   1   0
I have run out of steam and have reached the point in this project where I just need to cut my losses and move on. 1964 Dodge Dart 170 project, 2 door post. I have everything one would need to finsih this car except interior. Way too much goes with this car to list but here are some of the things that go with the car.
Fresh Paint 2002 Dodge White
Body de-trimmed
Fresh chrome bumper
Set-up for small block
TTII wheels with fresh tires
Fresh KH Disk brakes, rotors fresh BBP
braided caliper lines
Fresh Rear Brakes
8.75 with fresh 4:30 SG, BBP Yukon axles
Inboarded SS Springs
Fresh front suspension
Sub frame connectors
Adjustable front shocks
Fresh manual steering box
SS brake lines
SS fuel lines
Schmacker motor mounts
I have a fresh 273 motor and, 4-speed set-up but that will have to be set aside as another deal in that I have a lot into the set-up
$6000
John
[email protected] or [email protected]
I now have the car on the ground and rolling
Also to clarify the above the deal does not include the motor/ trans. I have too much into that so it will go separate. Also I forgot to mention that the KH disks are converted to big bolt pattern.
In addition to the other parts the following also goes with the car
New engine compartment wiring harness
Electric fuel pump
Rear battery kit with all the cables and wiring to following the MADD wiring set-up
The car will also have new fron and rear windshield boots as well as all the weather stripping for the doors.
Here is a more current pic
