1964 to 1966 Cuda Are your rear tires centered?
hotrodhoodlum
X Nostalgia Drag Racer
Bartlett IL 60103
I just installed a 28.5 x 9" x 15 Cheater Slick On my 65 Cuda and the left side is to far forward its hitting Anyone ever make spacers for the front hangers ??
these are for a B body car I dont need 2"
Those don't look like they'd be to difficult to modify or even fabricate a pair of yourself. If you don't have the equipment to do it yourself, I'm sure a decent machine shop could do it for you for not much money.
Which hangars did you purchase?
I purchased a set of Super Stock Hangers from Mopar Performance : CHICAGO CONNECTION for a B Body with 108" wheel base they have a 2" spacing . It has the same bolt pattern as my A Body . I then Had them re drilled to move the wheel back only 1" and cut off the excess . It took a couple of hours and I now run a 28.5 x 9" Pie Crust Cheater Slick
here is a link http://www.chicagoconnection.us/index.php?main_page=index&cPath=1_296_298
Front Hanger Bracket Set - 108/110/115" WB
(1964-65 Mod. B-Body, 1970-74 E-Body, 1971-74 B-Body Hard Top). These straight hangers are 2.0" longer for use with...
P4120080 Sale: $69.84
