The old steering wheel wasn't in the best condition. Some filler and sanding really smoth it out. Paint in two layers and a shot of clear coat and time for assembly. Turned out ok.
Very nice looking steering wheel. Nice work. Sgrip65
I have collected stuff since 1980 so it's almost history! Your sign loooks awesome! Actually Valley Dodge sold my wagon new to a couple from Lancaster. I'm gonna do a copy of the dealer plate ",Another one from Valley Dodge"! I found it behind the front license plate.i don't know which i like looking at more, your car or the shop. i see something new everytime
nice valley dodge frame. i live about 3 miles from there.
many years ago i got this sign from the plymouth dealer that was just down the street
Thanks Don. I got it vpnfirmed today too. Thpught about touch up paint!I’m pretty sure Glasurit is available here In the US.
Check against second picture in my latest post. I need a better emergency brake set up. How much?Got a bunch of wiring harness terminals - both male and female.
Were you asking about the exterior stainless trim? I have several mostly complete sets.
what’s stuck about the emergency brake mechanism? Is it the handle assembly or something else. I have pretty much a complete setup
A good two hours of body sealer workmade it. Turned out great so next step is to primer the whole body.
Yes, on the floor pans only. That will take away the vibrations.Ulf. Very Nice Work. Will you be installing Sound deadening? I installed this material in both my 66 and my 65 Darts. Made a big difference. Sgrip65.
I'm interested!If your heater core is leaking, how about a NOS core I have?
I'm interested!![]()
I do use a screw driver to remove the clips from the box. The problem I usually have is getting the clips back on without wrecking the box. There is a very thin edge that holds the clips in place and putting them back on very carefully and taking your time is the key.
Are you buying a rebuild kit or just cleaning the box up and putting it back together?
