1965 Dodge Dart high RPM issue
You may want to check that the correct speedometer gear is installed for your tire size and axel ratio. 20 bucks for the right gear, if needed is a lot cheaper than a speeding ticket.
Good point on checking for the right speedometer pinion gear. This chart is for the 904 transmission with 13 inch tires according to my 65 FSM:
Tire 2.93:1 3.23:1 3.55:1 3.91:1
Size
6.50-13 17-orange 19-Dk Blue 20-Green 21-Gray
6.70-13 16-Brown 17-Orange 19-Dk Blue 21-Gray
7.00-13 17-Orange 18-Dk Purple 21-Gray 21-Gray
These speedometer pinion gears are not being reproduced available only used. I think the $20 as referenced is for the later, common pinion gears.
