gdizzle
I bought this just for the speedo. And the front trim panel was missing. So I am selling the whole thing for parts. I have not tested any gauge so unknown if they function. I did inspect them and none of the wires are fried, though the needle on the ammeter looks melty.
The needle on the gas and temp seem to work. I did test with a 9v battery real quick and the needles move.
The circuit board is also untested. I inspected it, pins are not loose, and everything is checking out with a continuity tester. should be cleaned.
Now some things: the left lower ear is busted off (very common), and one of the BLUE light caps inside is gone. Also the oil pressure RED lense is loose and the little mounting hole for it has been glued.
So hopefully someone can use this for parts.
$25 plus shipping.
$25 plus shipping.
