William Cowger
Active Member
383 A-BODY ENGINE MOUNTING PACKAGE. FOR A-BODY BIG BLOCK K-FRAME ONLY
1 ORIGINAL,DRIVERS SIDE ENGINE MOUNTING BRACKET,MEDIA BLASTED,POWDER COATED SATIN BLACK
1 ORIGINAL PASS SIDE ENGINE MOUNTING BRACKET,MEDIA BLASTED,POWDER COATED SATIN BLACK
1 NOS DRIVERS SIDE RUBBER MOTOR MOUNT INSULATOR 2465861 DATED 4/67
1 NOS PASS SIDE RUBBER MOTOR MOUNT INSULATOR 2536121 FEB 69
2 COARSE SHORT MOUNTING BOLTS WITH THICK WASHERS
4 M HEAD FINE THREAD MOUNTING BOLTS WITH THIN WASHERS&DIMPLED LOCKING NUTS
4 FINE THREAD NUT CAPTURED WASHER( ATTACH THE INSULATOR TO THE MOUNT&K-FRAME)
1 LARGE THICK WASHER&COARSE NUT THAT ATTACH THE INSULATOR TO THE PASS MOUNT
1 LONG SERRATED COARSE BOLT&THICK WASHER THAT ATTACH THE PASS SIDE INSULATOR TO THE K-FRAME
WILL FIT 1967 1968 1969 DODGE DART GTS 383 , PLYMOUTH '383 CUDA AND A FACTORY BIG BLOCK K-FRAME
$400 plus $20 insured/tracked priority mail large flat rate box
