[FOR SALE] 1967 A Body Big Block Manifold Set
dart4forte
Mesa, AZ
Rating - 95%
19   1   0
i am offering up a set of A Body Bigblock manifolds. Driver side manifold is 2899002. Passenger side is 2863900. The passenger side manifold has the complete heat riser minus a small spring.
The driver side manifold had a crack in the front mounting tab which eventually broke off. I had it repaired through fusion welding. I'm in the finishing stage of getting that taken care of. I'll be taking it to a machine shop this week to have the mounting surface trued. All I will have left is to finish grinding to the tabs original shape and drilling the hole.
I'm offering these off to someone looking to finish off their 67-69 GTS big block resto.
$800 plus shipping for the pair. Normally these sets sell from $1200-$1500. I'm selling a little less due to the repair.
PM me if you are interested.
First two pics is where the tab broke. As you can see it got into the port. The third pic is the repair. It was fusion welded. Basically dense cast iron weld. There's enough metal for me to re contour the tab and drill the hole.
