1967 Dodge Dart Gt
norcaldp90
New Member
Novato
Rating - 0%
0   0   0
Second Owner 1967 Dart Gt. Super Stock Project. Original 273/904 car, No Motor or Trans. The hood and left fender were changed out sometime in the late sixties due to a small "fender bender" as the original owner told me. The rest of the car has the paint that it left the factory with. Not saying it's in great shape and that it doesn't need a little love, but you see exactly what's their. Nothing is hidden by body fillers, quickly sprayed on paint jobs. Their is no "ready for paint" primer and guide coat B.S. here.
What's been done so far:
The original owner had the interior recovered with a non factory cloth and color.
Bucket seats center console car.
Have the mopar performance motor mounts to install a big block to this K frame.
Complete front end rebuild: upper and lower ball joints, inner and outer tie rods, control arm bushings, strut bushings, idler arm, pitman arm, frt shocks.
Factory four piston caliber front disc brakes: new rotors, calipers, wheels bearings, brake hoses. Fuel tank has been cleaned and tested, 3/8 Hemi fuel pickup sender unit installed.
Complete rear suspension rebuild: 8 3/4 rear end, 4:10 posi, Mark Williams Hi-Torque axles, new wheels bearings, Mark Williams wheel studs, rear brake shoes, turned drums, wheel cylinders rear brake hose, rear shocks, Mopar Performance Super Stock rear leaf springs, offset spring shackles, offset spring hangers
All these parts have zero miles on them.
3800.00
