February 1967
~ Mopar Flash Bulletin for Performance on the 440 ~
Knock 5/10's off your E.T. with a 'Quickie Performance Kit'
Kit Includes
* Intake Manifold Heat-Crossover Block Gasket
* Carburetor Heat-Riser Spacer
* Pre-set Champion {J-10Y} Spark-Plugs {Colder Range}
* High-Performance Metal-Core Spark-Plug Wiring
* Special Wire Connectors
* Distributor Curve Kit {Lighter Springs and Special Counter-Weights}
* High-Performance Contact Points
* High Performance Distributor Cap
* Carter AFB Carburetor Performance Kit {Larger Secondary Jets and Metering Rod}
Kit Includes
