73SlantSwinger
Up for sale is my 67 Valiant Signet. Originally a slant six car, now has a 318 with Edelbrock aluminum heads and a nice choppy Voodoo cam. Transmission is a 727 with B@M floor shifter, 8 3/4 rear with 3.91 Sure Grip (489 Case). Interior has digital tach, aftermarket Volt, Oil Psi, and Temp guages. The factory gas and temp guages don't work, everything else does. The previous owner did the resto on the car, according to him took around 2yrs to do taking his time. I would classify the car as a very clean driver, not a show car. Since I've had it (around a year) I've done floor mats, replaced inside and outside door handles, arm rests and bases, driver's side mirror, smaller steering wheel, dimmer switch, headlight switch, instrument cluster bulbs, battery with new negative cable, and just recently put some bigger tires on the front with alignment and torsion bar adjustment. Car is quick for a 318 and gets a lot of attention! I'm not sure of the mileage on the car but I've probably only taken it out 15-20 times since I bought it. No rust that I have seen, extremely clean underside of car. Reason for possibly selling is we just bought a house and could use the $$$. I know I'm leaving something out so feel free to ask questions. I'll do my best to answer them. The only trade I would consider is a 67-69 Cuda fastback or $13,500
Car is located in Macclenny, FL just outside of Jacksonville.
