1968 440 pistons, flat top or valve relief ?
DonnieLawson
68 Barracuda
Middletown Ohio
are the stock pistons in a 1968 440 a flat top or do the have valve reliefs as shown ?
Thanks guys
Cool..... Found a used set that I want to put in my old ratrod to up the compression that has a late model truck engine.. Just trying to keep the cost down
The pistons are way down in the hole, compression is crap, It's way over cammed but sounding angry :) and oil pressure is down ... I had the 906 heads redone and hardened seats put in. The cylinder walls looked perfect. Engine was out of a motorhome... Just wanting to put new bearings in it and freshen it up .. Thought I would try to make it a little stouter and more fun by getting away from the 8-1 pistons in it
Six Pack pistons are cheap.
i'd like to see more pix of tha truck and i would spend the couple hundred $ for a new set of pistons...then you'll have a no worries 440.
