[SOLD] 1968 dart door $30
tiredoftrio
el monte ca.
I have what I think is a 69 dart door. Came with some sheet metal I bought years ago. There’s bondo coming out the back see pics. $30 Located in West Covina Ca 91791. Local Pick up only.
EDIT.
Corrected the years I noted earlier...
Assuming it is a dart, looks like it it would be a 68 as the door lock button is all the way back.
69 (IIRC) they were moved forward 8 inches or so.
And as has been noted after this post, hole for vent window screw is a hole (68) vs a fillet for a screw (67)
Thanks for the corrections. At least I knew it wasn't a 69!
Vent window access hole on upper trim and rear lock hole it's a 68. 67 the vent window access hole was a stamped countersink for a chrome screw. 68 and 69 it's a straight hole for a plastic plug. 69 they moved the lock knob forward on A and B body cars.
