howiedodat
Active Member
Here is my 1968 Plymouth Satellite. The information on the car is listed below. Everything below I have done to the car in the past 5 years I have owned it. The body and paint are an older spray. Looks very good but it is a driver with a few chips and scratches. The lower quarters were nicely done by the previous owner. There is a patch on the driver's side floor about the size of a grape fruit. The car is an undercoated car and shows no rust thru anywhere else. New ART sub-frame T Caps have been welded in by me. One side was beaten up by years of floor jacks. The other had been bondo covered by the PO (that was a nice surprise) and had to be trimmed to remove the rust and then the cap welded in. The car, before I purchased it, was being raced. The quarters and wheel houses had been "radiused" for the slicks. The wheel houses have been rebuilt a little more open. The 315's being run fit perfectly. With the proper wheel spacing and an 18 or less wheel size you can get 335's IN the wheel wells, IMO. Originally a slant 6 car auto on the column. Dash lights work, but do not dim. Gas gauge works as does the speedo. The in dash temp gauge is not hooked up but did work. The factory AMP gauge is bypassed for safety. Heater and blower work but the control cables are stiff. Wipers work on both speeds. Previous owner claimed the mileage showing is the original miles on the body. I cannot confirm that but the body and frame are solid. Doors, trunk and hood close nicely. Hood is on the original latch w/ hood pins. The car is and has been stored inside. The car has won many a local show but it is a driver. Runs, rides, shifts, stops and steers very nicely.
>360 LA .30 over 9.5 to 1, Hypereutectic pistons, casting number shows it to be a
1971 block
>292 Magnum Comp Cam & Lifters, .510 lift, new less than 2000 miles ago
>Edelbrock TR5 Street Tunnel Ram, purchased new less than 750 miles ago
>Edelbrock 1404 500CFM carbs, complete rebuild w/ floats less than 750 miles ago
>Summit Velocity Stack air cleaners, 8 inch round, new last week
>Edelbrock Aluminum Heads 1.80E 2.02I, less than 2000 miles ago
>Aluminum Roller Rockers, new less than 2000 miles ago
>Mopar Performance rocker shafts, purchased new less than 2000 miles ago
>Mopar Performance rocker shaft retainers, new less than 2000 miles ago
>Edelbrock Elite Aluminum tall valve covers, new less than 2000 miles ago
>Edelbrock 100 Shot installed, jets to 250HP included, Bottle is FULL, system
is on a WOT switch, purchased new less than 750 miles ago
>Poly Lock motor mounts in car, including w/sale --solid steel
mounts, purchased new less than 750 miles ago
>Trunk mounted battery, purchased new less than 750 miles ago
>Flaming River remote battery disconnect, new less than 750 miles ago
>MSD 6AL Ignition, 6500 RPM limiter pill, purchased new less than 2000
miles ago
>MSD Ignition Retard box, set for 4 degree retard w/ nitrous activation, 10
degree retard at start up, purchased new less than 2000 miles ago
>Pro Comp Billet distributor, purchased new less than 2000 miles ago
>MSD Blaster 2 coil purchased new less than 750 miles ago
>MSD Profire wires purchased new less than 750 miles ago
>NGK V Power plugs purchased new less than 750 miles ago
>Edelbrock high volume fuel pump 3/8 line and inlets purchased new less
than 750 miles ago
>New fuel tank, 3/8 line front to back purchased new less than 2000 miles
ago
>New fuel tank sending unit, 3/8 feed, purchased new less than 2000 miles
ago
>Dual remote oil filters w/ stainless lines & aluminum fittings, purchased new
>Champion Aluminum 4 row down flow radiator, purchased new less than
750 miles ago
>Dual 14 inch electric fans on a thermostat, purchased new less than 750
miles ago
>160 thermostat, hi flow purchased new less than 2000 miles ago
>Ceramic Coated Headers purchased new less than 2000 miles ago
>Dual exhaust thru Flow Master 40's out the rear
>Dual Electric cutouts, side exit at rear wheels, purchased new less than 750
miles ago
>Power Master High torque mini starter, purchased new less than 2000 miles
ago
>Performance Automatic 727 TF w/ PA 2600 stall, purchased new less than
2000 miles ago. Trans and convertor came together from the builder with a
LIFETIME warranty, non transferable unfortunately
>Lokar kick down cable, purchased new less than 2000 miles ago
>B & M Z Gate shifter purchased new less than 2000 miles ago
>Shaft Masters 3 inch driveshaft, steel purchased new less than 750 miles
ago
>B & M Tranny cooler plumbed w/ braided SS hoses and aluminum
fittings purchased new less than 2000 miles ago
>3.55 sure grip 8.75 w/ 489 case, all new bearings/seals though out the
rear/Richmond ring and pinion purchased new less than 2000 miles ago
>Rear brakes completely redone w/ all new hardware, shoes and wheel
cylinders
>Addco front and rear sway bars purchased new less than 2000 miles ago
>Mopar Performance leaf spring & shackle bushings purchased new less
than 750 miles ago
>Mopar Performance XHD leaf springs purchased new less than 750 miles
ago
>Mancini rear shock studs purchased new less than 750 miles ago
>95 Amp Alternator, rewired to handle the extra amps, purchased new less
than 2000 miles ago
>Clear glass tribar halogen headlights w/100 w Hellas on relays purchased
>Hitech LED tail lights purchased new less than 2000 miles ago
>Flaming River Satin Stainless 5 position tilt column purchased new less than
500 miles ago
>Power Steering, stock- no leaks
>Grant walnut steering wheel purchased new less than 2000 miles ago
>Kenwood AM/FM Stereo/CD mounted in glove box w/ dash mounted
remote, Polk Audio speakers purchased new less than 750 miles ago
>Front Disc brakes, A Body type with new spindles and rotors, NOT
power purchased new less than 2000 miles ago
>Adjustable Brake bias valve under the hood purchased new less than 2000
miles ago
>.96 Mopar Performance Torsion bars new less than 750 miles ago
>Tubular Upper Control Arm's purchased new less than 750 miles ago
>Boxed Lower Control Arms's w/ Mancini plates purchased new less than
750 miles ago
>KYB Gas Shocks , all four corners purchased new less than 750 miles ago
>Front end COMPLETELY redone, all new bushings, ball joints, tie rods,
etc. purchased/installed new less than 1000 miles ago
>AAR bolt on fiberglass hood w/ proper springs, painted single stage
flat black purchased new less than a few weeks ago
>Procar Rally Seats w/ Procar mounts and sliders purchased new last year
>Custom made white mats, embroidered purchased new less than a weeks
ago
>New blue carpet purchased new last year
>White seat belts purchased new last year
>Entire floor and behind rear seat done with Dyna mat heat and sound
deadener, purchased new less than 750 miles ago
>Sun Pro Tach w/ shift light purchased new less than 2000 miles ago
>Auto Meter Phantom Volt Gauge purchased new last year
>Auto Meter Phantom Electric oil pressure gauge purchased new last year
>Auto Meter Phantom Electric Water temp gauge purchased new last year
>New bumpers, not show chrome but nice
>Grille is perfect, no repairs
>Go Wing with proper mounting hardware for a 69 RR purchased new
>New windshield new in 2007, all other glass is good
>MB Old School rims, gray w/ polished lip new last year MAYBE 400 miles on
them
>245/45-18 fronts, Nitto Invo new last year MAYBE 400 miles on them
>315/35-20 rears, Nitto Invo new last year MAYBE 400 miles on them
PM me your email address for photos and contact information. The car and I are located in Dover, DE 19904.
As to price, Asking $14,500.00.
1971 block
miles ago
than 750 miles ago
ago
ago
750 miles ago
miles ago
miles ago
ago
ago
cylinders
than 750 miles ago
ago
than 2000 miles ago
500 miles ago
miles ago
750 miles ago
ago
them
