I’ll dig in a little deeper over there.... hard to go anywhere else tho, a lot of these guys here on FABO have been so much help and are so informative! really a bunch of good guys, even had the pleasure of meeting a couple of them! Lol
Picked up the motor and trans, got the motor pulled apart, gonna give it a nice little rebuild. The main bearings looked “ok” rod bearing the same, no groves or cuts in the crank, cylinder walls deff glazed with small ridge at the top but a good start for sure
This trans also isn’t the super low 1st gear, it’s the close ratio 4.56:1 1st which will be fine! I am going to go through the trans with new bearings, syncros, and gaskets
