[Found!] 1970-72 Duster or 1971-72 Demon
lvd2340
Richmond, Massachusetts
Rating - 0%
0   0   0
Looking for a 1970-72 Duster or 1971-72 Demon body. Something halfway decent nothing with major rust. One with an 8-3/4 rear would be a plus. Even a roller would be fine car is going to be used as a street/strip car. Prefereably located in the northeast.
you get what U pay for. my VS29H0 duster with low miles is worth way more, no? 340 steel crank, J E pistons, balanced, 4 gear, 8.75" high back buckets, all original metal, etc?
At this point my father is probably not looking to spend more than $4500
Sell the TA block, jobs done.
The NM car is all set up...mini-tubbed, caged, four link.....what is he waiting for??
you get what U pay for. my VS29H0 duster with low miles is worth way more, no? 340 steel crank, J E pistons, balanced, 4 gear, 8.75" high back buckets, all original metal, etc?....
^^^or, just buy the local option.
too bad you are so far away I have a 71 demon roller 8 3/4 BBP rear end SS springs BBP front end 11.75 disc brakes powder coated sub frame connectors welded in roll bar $5000
big bolt pattern, Harland roller rockers, narrowed rear, Hooker 1.75" , 2.05" manley valves, LD340 intake, runs 11.6 at 116, not for sale today but ? will ask $22,000.
Honestly - pay someone local go verify its condition for you, and if it's good - work a deal and have it shipped. You will sppend a lot more uncovering and fixing hidden BS with most anything in the northeast in that price range.
Way out of our price range, we're just looking for a donor body something inexpensive even if it needs some patchwork that might be ok. Gotta have a good frame.
