1970 Dart Leaking Rear Window
dd70340
Springfield, PA
I found out my rear window leaks into the trunk when I got caught in a downpour on the way home from a car show two weeks ago. The leaks occurred at the bottom corners. I read an old post that stated there are two different rear window seals, one for cars with a vinyl roof and one for cars without one. Here are two pictures of the corners of my roof. Is there any way to tell if this is the vinyl roof or non vinyl roof seal? I suspect I may have the vinyl roof seal which could explain the leaks. If it is the vinyl roof seal is it possible to seal the window using that seal on a non vinyl roof or do I need a new seal?
