[Found!] 1970 Duster LH Door Jamb Lock Pillar
JeremyAB95
Ohio
I'm trying to procure a left hand side door jamb lock pillar for my Duster. I see that Auto Metal Direct has them, but I don't want to spend almost $200 on a lock pillar - so I'm trying to see if anyone has a used one they can pull from a parts car.
Thanks.
Do you need the entire panel, or can you get by with a patch section around the striker post and cage.
I have those for $25 each
I'd prefer to have the complete thing if possible. I am already seeing what Bddodge has to offer - but stay tuned because you may have some other parts I need. Those would be the driver's side rear frame rail (complete assembly), left and right inner and outer rear wheel wells, and a patch panel for the lower portion of my cowl close to where it joins with the firewall. I will post up new threads for each of those parts. Thank you,
I have a real nice complete drivers side from a 74 Duster PM me if you still end up needing one
