ktcnn94
Thought about selling this car last year and changed my mind. Need to go ahead and let it go. It just sits around and doesn’t get driven much.
1971 swinger, 340 (‘71 block 360 heads) .030, air gap, Doug’s, Flow masters with turn downs, lunati cam, new Holley carb. 727 (rebuilt local couple of years ago, not many miles), Hughes converter, 8-1/4 rear narrowed 6” (3” per side). Springs relocated (welded and bolted in) mini-tubbed (not a professional job by any means but appears to be ok). Interior decent, not worn out just kinda out dated, does have new carpet. Paint is ok (again out dated) has some rust places on quarters, the quarters have been patched previously, front floor pans have been patched but are solid, frame rails solid, trunk pan solid. Front suspension newer and tight, new rear leaf springs, Tires are new, 14’s in front with 15’s rear. Fronts 14x7 225/70/14, Rears are 15x10 with 295/50/15. Rear wheels are fairly new, fronts are older but still pretty nice. Brakes fairly new and work good. Has manual brakes with power steering. Original 318 car with a/c, all the a/c stuff was long gone when I got it. All glass good and windows work correctly, windshield has wiper blade scrape. All lights work, speedo and gas gauge work. Has aftermarket tach, oil pressure and temp gauges. Aftermarket CD player (dash been cut for it) and speakers in kick panels and package tray. Probably forgot something. It’s tagged and insured, I would drive it just about anywhere. Any questions, message me here, If you wanna call or like me prefer texting, message me here and I’ll give you my phone number. $10,500 located in southern West Virginia, clean clear West Virginia title in my name. 25901 zip.
