This came off my duster. there were some cracks in the upper part of grille and various tabs were cracked. I repaired those areas and gave it a paint job. Not perfect but a 2 footer. The lower bezel tabs are both broke and 1 very minute crack on one of the fins. One lower tab is detached.When mounted you will see none of the repaired areas. the lenses are pretty good shape with minor hair line cracks. The chrome park bezels are nice but one has some pitting on the underside where it cant be seen unless you get down under the grille. The headlight bezels are in ok shape. Few scratches and small dings. They were also cleaned up and painted.Pig tails are nice and work good. It comes with LED amber lights. Also comes with new hold down pins,headlight adjusters and bezel clips/screws. It does not come with the upper and lower trim pieces but you can contact "340 demon 72" for a pair. This is a 45 year old peice of plastic and is very fragile. Buyer beware,do not force fit it, and handle it with care or you will break and crack things. I will professionally package and ship so it arrives as you see it here.I put alot of hours into this piece trying to make it solid and nice looking. I think it came out way better than when it was on my car. Located in lancaster pa. 425.00 plus shipping.
