[SOLD] 1972 plymouth Duster $750
Tim's_72
Knoxville
Rating - 0%
0   0   0
Slant 6 car. Primered body. Passenger side 3/4 floor pan replaced. Drivers side cut out and new AMD drivers side 3/4 pan comes with the car. Trunk pan needs replaced and it needs front fenders. Comes with 83 wide ratio 904/318 long block needs rebuilt. All interior parts come with car with exception of front glass and front seats. Have everything else for it. Car has mopar performance subframe connectors bolted in but should be welded in eventually. Its on jackstands in picture has wheels and tires so it can roll around. Just lost interest in the project $900 obo needs to be picked up with trailer.
Fenders weren't correct for the headlight buckets and also tabs weren't there so i sold them to a friend.
Tail lights need some rust repair as well as the corners under the bumpers..
Front suspension and rear suspension that's under it.
Rear seat
Seat belts
Dash
Steering column
Heater box
Trim
Rear glass
New 3/4 AMD floor pan for drivers side
Subframe connectors
Bumpers
Wiring harness
No front fenders but have a pristine front grille upper and lower radiator/ grille supports
Tail lights
Headlight grille trim & buckets
83 318 long block & wide ratio 904 transmission
Off the top of my head
It's almost a complete car with slant 6 suspension for 750. 1500 was for the 73+ brake setup, A body 8.75 housing, big drum brakes, mopar drag shocks & drag springs and the car all together if I wasn't clear.
