[WANTED] 1972 side marker SPACER
j061093409
1970 Dart Swinger 340 Reg
Wethersfield, CT
This spacer is hard plastic and just the “lip” shows around the side marker lense. I will post a photo a little later. These start to deteriorate so really looking for NOS. I have side marker lenses but these did not come in the boxes. In Hartford, CT
Will get a photo of the gasket by itself but here it is on the car
I have never seen that gasket. Only the small foam gasket around the square bulb socket and the the foam washers on the plastic studs. I have some 72-74 A-bodies. I am curious now I have to look. Could they be from a newer or different body. I have markers from Omni rear and also truck front. I never saw these. Like I always said never say never with a Mopar
I really think on the Windsor Plant, 1972 Darts. I have another late production 1972 car that has them. 1972 Cars With late production seem to have these.
Interesting... never seen them before either. My 72 doesn't have them but maybe it should? :popcorn:
A friend of mine said he saw them on a van years ago and they were chrome plated around the edges. I still don't remember them.
That is the gasket that prevents leaks in the trunk & is still standard even in Van’s repop lenses.
The ones I need are different.
You are correct. Trunk only. Windsor plant. I have two used ones that look just like that.
