1973 drivers side BBP A arm wanted
I will take both If I have to I guess?
just need a good price..Anybody???
I have two pairs. Both pairs have an issue with the same side, but I don't remember which side that is. I'll be out later and can look. I have repaired one of the arms (crack on a bushing hole), but the other "bad" one has a tack welded ball joint, which is the factory fix for a stripped arm. If it's the repaired side I'd take $25 for that arm or $40 if it's the other side. It's also not that far of a road trip to come pick it up. I also may be going to South SF in a couple of weeks and could always meet up in Gilroy. I'll PM you my cell #.
Turns out the two I have that have/had issues are the driver side, but I'd trust the one I repaired. I would not sell it unless you see it in person to determine if YOU trust it, though. I will have them at Spring Fling.
