1973 Duster 440
cjcx3
Twisted Sundance
CARTERSVILLE GA
Rating - 0%
0   0   0
solid 1973 Duster 440
1973 Duster with a 1970 grille and AAR fiberglass 6-pak hood.
ENGINE: 440 +0.030, steel crank, Eagle CRS 6760 H-beam rods, KB pistons, ARP main studs, ARP head bolts, 452 bowl port and gasket match with 2.14/ 1.81 valve heads, Comp Cams hydraulic Thumper cam, Comp Cams roller rockers, Comp Cams Magnum push rods, Edelbrock performer RPM dual plane intake, Holley 850 cfm 4150 carb., Holley electric fuel pump, A body 440 699 oil pan, conversion motor mounts from Mancini, TTI chrome under chassis headers, Flow master exhaust with "X" pipe, 440aluminum fabricated valve covers, MSD ignition, MSD distributor, 90 amp alternator, aluminum water pump and housing, Griffen aluminum radiator with electric fan
TRANSMISSION & REAR : 727 transmission with deep pan and drain plug, Hughes 2500 torque converter, Cheetha manual shift reverse valve body, Hurst Quarter Pistol Grip shifer, A body 8 3/4, Auburn posi, 3.23 gears, adjustable pinion snubber, custom length and balanced drive shaft with new u-joints, new big bolt axles with Green bearings, late model aluminum master cylinder and 4 wheel disc brake proportioning valve, SSBC rear disc brakes.
BODY & CHASSIS: 1970 Duster grille, electric trunk popper, new door and ignition lock set, new side markers, weld in frame connectors, 18" wheels, rebuilt suspension - I replaced: upper and lower control arm bushings, upper and lower ball joints, inner and outter tie rod ends, pitman arm, drag link, rotors, calipers, brake pads, wheel bearings, rebuilt leaf springs with a 2" lowering blocks, manual steering, Vintage brand heat mounted under dash, Auto meter gauges ATM-5715 fuel level, ATM-5897 10000 rpm tach, ATM-5893 160 mph speedo, and ATM-5737 electric water temp in custom dash, ATM-5721 oil pressure and ATM-5791 voltmeter mounted under dash, EZ2Wire wire harness, L.E.D. tail lights, new upholstery on seats, new carpet, replaced wood grain dash panels, AAR fiberglass 6-pak hood, line loc, battery mounted in trunk, new trunk mat, Fiberglass bumpers, new outside door handles, new weatherstrip, body and paint are not show quality, but this is a very nice driver and very fun. I purchased car as a rolling body that had all ready been painted so I do not know exact color name/code. Contact me for questions. I have about 18000.00 in receipts. I performed all the work on this car except the body and blue paint, so ask any question about the car and I can answer. I DO DRIVE THIS CAR SO MILEAGE WILL GO UP. CAR IS FOR SALE LOCALLY buyer is RESPONSIBLE FOR A CASH ONLY PAYMENT IN PERSON, I can not ship, but may be able to trailer it up to 100 miles for a fuel charge. Price is 15000.00$.
Slowly I am getting time to load these photos
more
Guy's, I've seen this car the pic's don't do it justice!!! This thing freak'n scream's! He took me for a ride and I about crapped myself! It's scary fast! You can't build it for what he's asking! I hate to see it go but you gotta do what you gotta do! Good luck with sale!
I never thought I would see the day when a white boy could turn three shades of white.....still pulling finger nails out from the seat! LOL!
:burnout:
nice duster. good luck with the sell. it will make someone a nice ride
