You can also transfer all or part of one of your posts into another one of your posts .
You can go to say post 20 and hit EDIT, then highlight whatever part you want to transfer, by left clicking and dragging the highlight over the entire part that you want to transfer. Once it is highlighted, right-clic and a menu will drop down. Go down to "cut" and hit it. The program has now cut it out and cached it.
You should see a flashing line at the top left of your post, indicating where any new typing will occur; ignore it, and left clic on any dead space, and that post should be empty.
Next go to the post you want to transfer this to, Say post 19,and click on EDIT
Once in, scroll down to where you want to put the cached part, and left clic to get the flashing starter. Right clic for the menu, and go down to "paste". Left clic on that and the program should install whatever last thing you successfully cut out, right next to the flashing starter.
If the post you cut from, failed to delete, you can now go to the delete button and get rid of it that way.But if there is a part you left behind, and want to keep, then clic on "save changes"
It sounds complicated but after a couple of times you may using it a lot. You can edit as many times as you want to.
However;
If you state a "truth", and a day later, later find out you were wrong, it is considered "poor etiquette" to edit it out. Instead Write "EDIT" at the bottom, and make the correction in the edit. This will keep the "edit police" off your back.
If you look at the bottom RH corner of this post, you will see "last edited at such and such a time" . That's because I tend to add stuff to posts sometimes long after the original post went up. This post is one of those. You can look to the top left and see I originally posted this at "X minutes ago" . later it will have a time-stamp on it. You can compare those two and see how long I've been editing,lol. Hyup; I'm a really slow typer and I make a lotta mistakes.
