1974 360 engine
74's call for unleaded-I've had a few and that's what mine called for.
Really doesn't matter as you can't buy any at the pump and the valve seat thing that was predicted back in the day never really was an issue,other things will get ya before that.
You can get it at most auto parts stores! Lucas has one! Or you can order it from Summit! Comp makes it Redline etc. You can also get oil with it already in it! Brad Penn, Royal purple! It's pricey, but, a definite must! Almost every engine i've built in the last four years or so was due to a flat cam! Sadly the owners were not aware of this issue!
