[SOLD] 1981 D150 Slant Six 39,000 Miles
smitty040
Middle Tennessee
Motor pulled out of a Dodge D150 with 39,000 miles and from the pictures it looks like it as well. I only cleaned the outside, the inside looks as it did when I pulled the cover and pan. It's ready for paint and a new home. Water flowed through the motor with no issues and no gunk came out of the block drain plug.
Only selling because I found a great slant/transmission deal after noticing a few leaks in my current transmission and did not want to tear apart, re-seal, and to find out why after adjusting the kickdown linkage I got it to shift up at the correct speed but not downshift into the passing gear.
If you have a pre '68 transmission I have the adapter ring that will go with the motor.
I also have an extra single barrel intake, exhaust manifold, and Holley carb that I can package with.
Asking $400.00 OBO
Local Pick-up only
Located in Columbus, OH
Thanks FABO!
