[SOLD] 1986 Monte Carlo SS
dwire67
Seaford, Delaware
Had all intentions of driving this and things have changed.
The car has been gone over mechanically
New Brake system with vented grooved front rotors ,powder coated rotors, HD pads , bearings and seals
New rear drums , shoes, wheel cylinders ,hardware. new INLine tube brake lines front to rear with all new hoses.
New Coil springs and shocks
Carb was professionally rebuilt
New Radiator, Heater Core , hoses and belts
New Cap, rotor ,wires and plugs
New BFG Radial TA tires
All new door and window weather strips, trunk weather strip and mat
New Stereo
New Battery
All fluids changed and filters
Rebuilt steering column
Jeep steering link with u-joints -removes rubber rag joint
Needs new headliner
Needs front pump seal in trans, drips when it sits
A/C charged
$5500 or B/O Mileage is just over 100k that is what the title says.
Located in NJ 08510 Zip code
Few more pictures
Current Auto Check report
1986 Chevrolet Monte Carlo Base / LS / SS
many owners many owners Calculated Owners: 5
Class: Mid Range Car - Standard
Engine: 5.0L V8 4BBL
Country of Assembly: United States
Vehicle Age: 30 year(s)
VIN: 1G1GZ37G3GR143130
Year: 1986
Make: Chevrolet
Model: Monte Carlo Base / LS / SS
Style/Body: Coupe 2D
This vehicle's AutoCheck Score
The AutoCheck Score is a summary of your vehicle's history. It lets you compare similar vehicles with ease.
About the AutoCheck Score
This vehicle qualifies for Buyback Protection
buyback
Safeguard your investment with AutoCheck Buyback Protection. It reduces the risk in buying a used vehicle.
About Buyback Protection
Accident Check
Reported accidents: 0
Title and Problem Check
Your vehicle checks out:
Odometer Check
Last Reported Odometer Reading: 117,420
Vehicle Use and Event Check
No vehicle use reported
Your Vehicle Checks Out: AutoCheck's database for this 1986 Chevrolet Monte Carlo Base / LS / SS (1G1GZ37G3GR143130) shows no negative titles or other problems. When reported to AutoCheck, these events can indicate serious past damage or other significant problems, and disqualifies the vehicle for AutoCheck Buyback Protection. Check the Vehicle Use and Event Check for reported accidents that can affect vehicle safety and value.
0 Problem(s) Reported: 15 Title/Problem areas checked:
image No abandoned title record
image No damaged title or major damage incident record
image No fire damaged title record
image No grey market title record
image No hail damage title record
image No insurance loss title or probable total loss record
image No junk or scrapped title record
image No manufacturer buyback/lemon title record
image No odometer problem title record
image No rebuilt/rebuildable title record
image No salvage title or salvage auction record
image No water damaged title record
image No NHTSA crash test record
image No frame/unibody damage record
image No recycling facility record
Your Vehicle Checks Out: AutoCheck examined the reported odometer readings reported to AutoCheck for this 1986 Chevrolet Monte Carlo Base / LS / SS (1G1GZ37G3GR143130) and no indication of an odometer rollback or tampering was found. AutoCheck uses business rules to determine if reported odometer readings are significantly less than previously reported values. Not all reported odometer readings are used. Title and auction events also report odometer tampering or breakage.
0 Problem(s) Reported: Mileage Date Reported
image 12,272 04/03/1987
image 80,336 04/19/2001
image 110,877 04/30/2003
image 117,420 01/03/2015
Report Run Date February 5, 2016 7:43:34 PM EST
Vehicle: 1986 Chevrolet Monte Carlo Base / LS / SS (1G1GZ37G3GR143130)
Event date Location Odometer reading Data Source Details
04/03/1987 WRIGHTSVILLE, PA
12,272
Auto Auction ODOMETER READING FROM DMV
01/04/1997 WRIGHTSVILLE, PA
Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
01/30/1998 WRIGHTSVILLE, PA
02/01/1999 WRIGHTSVILLE, PA
02/02/2000 WRIGHTSVILLE, PA
03/27/2001 WRIGHTSVILLE, PA
04/19/2001 YORK, PA
80,336
Motor Vehicle Dept. TITLE (Title #:38223207)
04/27/2001 HANOVER, PA
11/30/2001 YORK, SC
04/30/2003 EDISON, NJ
110,877
Motor Vehicle Dept. TITLE (Title #:ED200312000000367)
04/30/2006 EDISON, NJ
04/30/2007 EDISON, NJ
01/03/2015 CLARKSBURG, NJ
117,420
Motor Vehicle Dept. TITLE (Title #:FR201500300000160)
07/31/2015 CLARKSBURG, NJ
