RAMCTD2003
340dart
I'm looking to sell my 89 Dodge D150 which we have built into a drag truck. Looking to sell as a roller with no motor or trans. The truck has about 35-40 passes on it total. It weighed right at about 3,200 pounds with a 340 small block and a 904 trans. Starting from the front it has a US body source fiberglass race weight hood (I will also send the original newly painted hood and front bumper with the truck) the paint is a 8/10 all around, 6 point roll cage, has a summit racing plastic seat with cover, g-force harnesses that are brand new so still in cert, turbo action cheetah scs shifter, aluminum door panels and dash, 5 inch tach with shift light, autometer water temp, oil pressure and volt gauges, painless wiring harness which is wired to switches on the dash for ignition, fuel, electric fan, electric water pump, tail light and start. New Optima red top battery. 4 core radiator with electric fan, trans cooler, 10 gallon aluminum fuel cell, all fuel lines are braided with AN fittings all the way up to the engine bay, holley black fuel pump and trick flow fuel filters. Holley billet fuel pressure regulator with return line. It has four brand new Weld Drag light wheels, 15x3.5 up front with new front runners, 15x8 with 28x9.0/15 hoosier slicks in the rear with maybe 35-40 passes on them, 8 3/4 rear end (489 case) with 4.86 gears, Richmond spool and custom 30 spline Moser axles. Truck has been lowered 4 inches in the front with custom front control arms from mid America customs and 6 inches in the rear with a flip kit. Will send the truck with a 4 inch driveshaft for a 904 trans as well. As you can see there has been a lot of work put into this truck and I'm sure I forgot some things so please feel free to ask any questions.
Located in Grand Junction, Colorado. Clean Colorado title in my name.
Asking $5000 OBO no trades please. Thanks for looking!
