blackdart66
Member
- Joined
- Feb 7, 2009
- Messages
- 23
- Reaction score
- 6
Got a great deal on a 5.9 going and have a few questions....Car is an early A, 66 dart.
1) will the "front" of my 273 all bolt on the magnum ? Timing cover, pulley's etc. I am pretty sure I have to use the magnum balancer.
2) If thats a yes will the oil pan off the 273 work with the magnum engine and the 273 timing cover ?
3) Spit fires will work fine on the magnum heads ? They are already on my 273
I am just starting to put the list together......any other pit falls ? I am aware that I'll need the cam extension for the mechanical fuel pump, the right flex plate and converter and of course the intake and carb. I am also assuming my current ignition system will work......Thanks all !!
