Thanks to all in advance.
I rebuilt the 318 in my dart and have driven it for about a year and put ~1,100 miles on it has been mostly good. 318, 30 over, KB flat tops, Comp XE268H, Eddy air gap, Eddy 650, tti headers.
I have done some reading lately that states high oil pressure is not good for the engine. Since the rebuild the oil pressure sits at 80 when warm at idle and maxes out the gauge when driving around easily.
I bought a new oil pump and oil pan gasket set. Before doing the work I figured I would just get some confirmations that high oil pressure is bad.
I have had troubles with oil leaking out of the dipstick tube and valve cover cap.
