stumblinhorse
I read all the posts about "don't waste time on a 318 just swap to 360". I have researched it and that doesn't seem like that is cost effective anymore. I am sure I am missing something tho! I think to do the swap you have to get a new flywheel that is balanced for a 360. Those are at least $200? Not sure where you get one of those that works for all bell housings and starters? Also that means new clutch etc if you have a manual. Also you have to find a 360 block, Currently those are about 6-7 times the cost of a 318 block. $750 vs $100. I even see 340 blocks cheaper and more available than 360s on my local area craigslist.
So already you are into the swap for $1000 more for a few more horsepower. I know I am not that knowledgeable in all this stuff so please correct me.
I think a nice 390 stroker is the most cost effective way to to upgrade. Not a whole lot more money then simply redoing a 318 stock.(depends on the heads you want!)
