[FOR SALE] 340/360 Windage tray
littleredcoffin
keene nh
Windage tray only.NO Bolts.$35.Keene NH.US Postal money order only.
Which is it?
Can't be both. 340 has narrow spacing. 360 has a wider spacing.
Different size mains
Tom
All, the slotted holes will work for all small blocks 273, 318, 340, and 360. You need 2 hardened .125 thick washers under the main bolts to use with 273 or 318, unless you have the special shorter 318 main bolts for the tray.
