i got a 340 out of a 73 boat .i want to put the 340 in a 70 dart but i need to change the cam so ive been told.what kind of cam should i go with .any other input on what other steps I should take will be very helpful thanks.tigey
First thang you better do is make sure that damn thing is set up to run CW.
What kind of boats came with 340s? That would be kinda cool.
. Only time you run into an opposite direction motor is with dual motor setups to counteract the side thrust. If boat was an original single motor, should not be a problem.
thanks for your input"67dart273"its clock wise .i will look into the other items you mentioned i .dont know what a crank seal flute is.MOPEkidD-3 iam about 20 west of aspen.thanks guys ill wil post pics soon
tigey
If it's a runner great if your going to rebuild it have it sonic checked, boat motors can have bad erosion and a lot of rust in the water jackets, a lot depends on how much use and if it was properly winterized
