340 dip stick length
jawbone
Cuda_queer
Richardson, TX
What is the correct dipstick length and tube connected to block length for the an LA340? After changing the oil and adding 5 quarts, the level is showing approx. 1 quart low. Making use of Milidon 5 quart oil pan. Engine makes use of 1 quart filter and was run prior to checking oil level. This is a engine startup/break in after rebuild. Have no reason to think dip stick is incorrect for engine but got engine in pieces.
Are you sure you have a 5 quart base pan?
Is it this one? If so , its 7 quart.
