downsr
What does every one use on 340 intake to seal it in the front and back.Do you use gasket and
sealant or just rtv or some other sealant.I was also told some use a plate in the front and back then set your intake on that.Is there such a plate you can purchase.Finally if you run a
breather on each valve cover should you still use pcv valve .Thanks
