340 (LA) Roller Rockers
Haney
www.carsonandironmt.com
Piney Flats, Tennessee
I have a 340 with X heads. What is the best bang for the buck for streetable roller rockers? I also have plans to update to a set of Eddy Heads I have had for a while sometime soon, so I would want to use them on both heads if possible.
Thanks,
Jamie
Mike from b3 sold me the prw stainless steel rocker arms just last fall and he has geometry correction shims to get your setup dialled in.
after installing roller rockers and lifters i got to say a waste of money , more work to set up properly and depending on make the quality might suck .
for most hyd lifter street builds roller rockers are a waste of money
500-525 stock rockers
550 iron rockers
more than or even less than that solid lifters then think about roler tip rockers AND mikes kits
