340 PCV grommet question.
flathead31coupe
indianapolis indiana
I recently inquired a 340 duster and it has Mopar performance valve covers. It has one cap on the passenger side and a breather on the other side. Does anyone know the correct grommet that will go in place of the breather on the passenger side that I can put a PCV valve into?
I don't know which grommet you need, BUT you need a breather on one side and the PCV on the other. The breather is the inlet for the PCV system. Pictures would help you get some better answers.
Thanks. I've been looking and I think I found a grommet that will go down and twist in a standard breather hole and a valve cover the kind that twist and lock. There's a grommet that does that with a hole in the center for a PCv valve
This looks like it may do what I need.
