I asked this question in my project thread and it hasn't gotten a whole lot of attention. My 69 Barracuda 340 4spd has an issue of popping through the carb during acceleration at low RPM. Most notably when taking off from a stop sign. If I baby it and accelerate slowly, it wont do it but every normal attempt it pops. If I leave hard with more RPM it works fine. Engine idles perfect and runs great rolling down the highway. Problem seems to be worse once it warms up. I have messed with the timing a little in each direction with no change. All my ignition components are new as well as the carb.
Ive read similar posts and many suggest a worn/wiped cam. If this was the case, I would assume there would be some valve train noise. My engine is noise free.
Thanks in advance for the help guys! This is my first Mopar and will definitely be learning along the way.
