340 Pully
it will bolt on, as pishta said, you can make it work. i have 4 bolts holding on one of mine because of the offset holes that i didnt make bigger, yet
Thanks...got one...Didn't want to change the one I have cause if it don't fit the 340 I'll need it later for the 318 anyway.
Curious when the 340 pattern changed. The 318 went to the symetrical pattern in 72, so either
a) the 340 kept the offset hole through 73
b) the OP's "72" 318 is really a 71 and earlier
c) that particular 318 was built with leftover 71 parts
d) somebody changed dampers
Just curious what the deal is.
