It's ALIVE!!!
Just fired up last night a broke in the camshaft, that was a loud 20 mins in the garage!
Took a couple refills of the carb bowls before the fuel lines primed, but then she was good to go.
Engine runs smooth, with the oil gauge steady at 40psi idle up to 70psi at 2500rpm.
It got up to about 200°-210° during break in, I was spraying down the rad to keep it down. Hopefully the cooling system will keep up in traffic.
Anyone know which shrouds will work with the Spectra CU526 rad?
It looks like a replica of the 22" that came in these cars, and had the mounting tabs.
