360 magnum + windage tray.
mopar65
Laquey MO
Hi. I have a 91/96 dakota race truck with a 2000 360 magnum engine. I am useing the stock 5 qt dakota oil pan. Well I had to replace my leaking rear main seal. So while I have it torn down I figured now would be the time to add a windage tray. But not sure which one to get. Huges website says there LA tray won't work with the magnum engine. So does anybody have any info or advice
Looks like you're gonna have to modify one. I don't where anybody makes one that's compatible.
I used a stock 340 style on my 5.9 with a 360 car pan, seemed to fit fine with the mopar replacement main bolts.
I would also weld some baffles in the pan to keep the oil down in the sump area while under accel and decel.
