1970 La
Just got my block back from the machine shop and I noticed a crack in the block on the thrust main. I had them put new main studs in and alignhone it. The crack is on the inside of the main and does not look like it is cracked to the bolt hole. Is this a comon problem on a small block?
Can post pics if wanted thanks.
