360 sb. 2bbl iron intake or 4bbl iron intake with 4bbl to 2bbl flat plate adapter, which flows the best? thank you for your time. RR
If may ask 92b how does the 2176 compare to the 8022 power wise? Thanks!
It's been a while since I did that testing. We have to run a holley 4412 so the testing was done with a couple of different 2 to 4 bbl adapters and a couple different 4412's. If I recall correctly the power was similar with the 8022 making slightly more. But on my motor the ede. had better fuel distribution and ran smoother below peak HP. A friend of mine was running the 8022 and said his motor made a little more power with the 8022. He said he had no issues below peak hp. The manifold comparison might have different results with a 4 bbl.
I always ran the 8022 because of the height, but the last few I got (5-7 years ago) the ports were terrible for consistency, makes me think I should have tried the 2176. All water under the bridge now,thanks much!
Imca won’t let you grind anything, supposedly.
Thinking taller was better (8022), only had 1 2176 but never had a use for it at the time.
