360 w/J heads KC Craigslist $60!!!
BrianT
Here we go again...
Kansas City, Mo
Not mine and I don't have room to store it right now, but someone needs to go grab this up!
http://kansascity.craigslist.org/pts/5323217288.html
Hey, man, you're slippin. How 'bout the 833 for a hundred?
doesn't it look like the waterpump impeller clearanced itself into the timing cover?
I would expect a ton of aluminum shavings to have made it through the coolant passages and the I would suspect the whole motor to have overheated
It does
Werent all OD cases aluminum, or was that later years????
Jake
I saw it, just never had any interest in those OD transmissions.
$60 for a decent 360 block is a good deal. Anything else that is usable is just icing on the cake.
Turns out I know the guy. I sold him a four speed set up a couple of years ago when I was in a pinch and needed cash.
Both items were sold last week.
Jake
i've pulled iron ods out of aspen/volares...75 and 76 models.the cases are good for 4 speed swaps and you get the big front bearing.way better than the aluminum od because you don't need to bush cluster gear shaft.
mike bee
