3769974 360 Heads
68 CUDA FORMULA S
Clarkston Michigan
This 340 motor that I have installed in this 68 barracuda has 360 heads on it. They are 3769974 heads they have the 202 intake valves and the 160 exhaust valves all new stainless. My question is are these heads like the other small block la heads that have the water jackets in the front and back for the exhaust manifolds. I have installed headers but do I need to use the high temp sealer on the front and back header bolts.
Thanks
Bob
Thanks
Bob
Yes, like all small block heads you need sealer on all 4 corners of the exhaust studs.
