383 2bbl on a 318??? will it work?
Discussion in 'Members Restorations' started by Valiant123, Feb 16, 2017.
  1. Valiant123
    Valiant123 New Member
    4
    0
    Feb 25, 2012
    Auburn
    Local Time:
    4:07 AM
    Can anyone advise me on putting a new 2bl for a 383, Chrysler #1530373, carb on my 318?
    My Carter model 2425 is done! Will it work?
  2. whitepunkonnitro
    whitepunkonnitro FABO Gold Member FABO Gold Member
    13,729
    765
    Dec 6, 2011
    Murfreesboro Tn
    Local Time:
    6:07 AM
    You would have to use an adapter or swap to a 360 2bbl manifold
    • Agree Agree x 1
    • Valiant123
      4
      0
      Feb 25, 2012
      Auburn
      Local Time:
      4:07 AM
      Oreilley's or specialty like summit?
    • whitepunkonnitro
      13,729
      765
      Dec 6, 2011
      Murfreesboro Tn
      Local Time:
      6:07 AM
      That I couldn't tell you.
    • Valiant123
      4
      0
      Feb 25, 2012
      Auburn
      Local Time:
      4:07 AM
      OK I think I got it covered. Mr gasket 2bbl adapter ordered. Is the 383 a larger bolt pattern on the intake? Thanks for the help btw.
    • Valiant123
      4
      0
      Feb 25, 2012
      Auburn
      Local Time:
      4:07 AM
      Also I have an open intake not the 2 hole kind. It's a large oval so no interference to the butterflies I'm guessing. I haven't seen the 383 carb yet. Guy has one for sale for $125 locally. My 0-2425 is falling apart, not worth the trouble. Can't afford to upgrade to 4bbl yet.
    • younggun2.0
      younggun2.0 Well-Known Member
      4,574
      595
      Jan 27, 2012
      federal way, wa
      Local Time:
      4:07 AM
      You could get used parts for about that and go 4 barrels
    • kaytbugsdad
      kaytbugsdad Well-Known Member
      210
      16
      May 10, 2011
      Galt CA
      Local Time:
      4:07 AM
      I swapped a stock Holley carb and intake from a 75 360 2bbl van for about $100...... Works perfectly now, much better than the garbage Carter I had on it before!!!!
