Aloha, I am restoring a 68 Barracuda Notch Form. S. car is in pieces when I bought it. trying to get an idea of the 383 motor mounts . Any help would be great. Thanks, C
I NEED THEM MOUNTS, DID NOT COME WITH THEM !!! MANY THANKSIf you're going the stock route, here's a few pics I've saved over the years...
That is how my 383 is !On original BB engines in "A" cars, not only did the block have the the two forward bolt holes threaded, but the factory cut off the rear, unused "ear". So in an original car , both will be present.
I thought 67 and 68 centerlinks were diff. I will have to look into it. ThanksJust an FYI, your steering centerlink in pic #4 looks incorrect for a 68. That looks like a 73-76 A body centerline. Correct A body 67-72 center link should look like this.
Only thing thats different is the idler arm. 67 1 year only k frame because of idler arm and mount. Here is pix of 67 K frame i am modding to the 68-76 style idler arm mount. You can see the old mount attached in first pic.
I have this link also, would u have a set or motor mounts ?
Many thanks, Any and all help is very much appreciated. Mahalo CNo big block mount stuff. Thats the correct link 67-72. That link for new mounts they seemed fairly reasonable for new big block mounts.
PS who makes Broadcast sheets ?Well you have the data plate, and vin. With these, a new broadcast sheet can be made. Pretty color its going to be by the way. I am partial to blue.
Chrysler Historical Society is where I got mine a couple years ago. I think they're still doing it.PS who makes Broadcast sheets ?
Ah, How Sweet !!!With as good a job you have done on the 67, i think your just the man for the job on this 68
